Does a 58mm TB Really make a difference?
Old Dec 19, 2007 | 07:01 PM
showstoppers-96-Z/28's Avatar
On a stock set of heads, stock displacement, and along with the mods in my signature...if i port matched the intake would a 58mm throttle body really make any difference in performance at all? Slight HP increase, maybe just a better throttle response? I was just curious, that would end up being my next little bolt on if i see it as worth it, when i go to a 383 setup, i know im going to need it but for now i just wanted some insight on it as to whether or not it would make any real difference. Thanks for ur time
Old Dec 19, 2007 | 07:52 PM
<Puck>'s Avatar
You will get the feeling of better throttle response from the "tip in" of the larger blades, but there will not be much of a power increase - a stock headed, stock cube LT1 cannot move enough air to warrant a 58mm TB unless you spin it to impossible RPMs. At 6500 rpms a 350ci engine can only possibly move around 660cfm of air - well under the 1,000 or so CFM of most 58mm TB's, and much closer to the ~750 cfm of a 52mm unit.
Also, you will have to deal with things like idle tuning(maybe having to drill out IAC passage and/or seclude it), resetting TPS sensor, and a possibility of shifting problems on autos due to the vehicle being at different speeds per throttle percent vs the stocker.
For stock/bolt on LT1s 52mm is a nice upgrade from stock without a lot of the hassle from a 58mm piece.
Jan 23, 2015 01:13 PM
InfernalVortex
Jan 17, 2015 09:35 AM
Rich_z28
Sep 8, 2002 12:00 AM
$hawn
Aug 28, 2002 09:09 AM
