Do you think a tune will help?
Old Jul 5, 2006 | 03:54 PM
fattyz28's Avatar
My '94 stumbles from a take off or under a load. Almost like it is cutting out. Ever since my car had a short in the wire to the coil, I have had this problem. I replaced a section of that wire, but the problem persists. The mods are in my signature. Any help would be appreciated.
Old Jul 5, 2006 | 07:12 PM
String's Avatar
Re: Do you think a tune will help?
You might check your ignition module. Autozone will do it for free. It is located directly above the stock coil.
Old Jul 5, 2006 | 09:56 PM
fattyz28's Avatar
already replaced it.
Old Jul 6, 2006 | 04:25 PM
2QUIK6's Avatar
You must first find the source of the problem. Any EFI owner should get a scan tool. Its worth its weight in gold in trouble shooting problems.
Maybe your stumble is because the IAC is mis adjusted or stuck open/close. Maybe you have a stuck injector, the scan tool would show your fuel integrators/BLM values indicating if its constantly adding or removing fuel...could be a bad ground, bad connection somewhere....bad plugs, vacuum leak, exhaust leak before the O2..
Old Jul 6, 2006 | 04:48 PM
97WS6SCharged's Avatar
Have you checked the cat(s) and fuel filter lately?
Old Jul 6, 2006 | 08:14 PM
LiT1_up's Avatar
Coolant temp sensor?
Old Jul 6, 2006 | 08:17 PM
fattyz28's Avatar
Fuel filter has been replaced, and I don't have a cat.
Maybe I should invest in a scan tool. Any suggestions on what kind?
Old Jul 6, 2006 | 08:18 PM
fattyz28's Avatar
How would a coolant temp sensor affect this?
Old Jul 6, 2006 | 08:26 PM
It tells the computer that it's -75 degrees outside and the computer adds tons of fuel.
Old Jul 6, 2006 | 08:33 PM
besz28's Avatar
spark plug wire
Old Jul 6, 2006 | 08:52 PM
fattyz28's Avatar
I would like to think it isn't the wires, they are new and so are the plugs.
Old Jul 6, 2006 | 09:34 PM
Javier97Z28's Avatar
Moderator
A tune will not help a "stumble" on a bolt-on car.
Old Jul 6, 2006 | 09:40 PM
95LT1conv's Avatar
javier hows the new motor running. get the oil pressure situation under control?
Aug 24, 2015 06:41 AM
sherwinZ28
11
Aug 15, 2015 05:38 PM
RallyRed701/2
Jul 27, 2015 02:55 PM
colts0455
Jul 24, 2015 04:51 PM
Shookiez28
Jul 23, 2015 01:55 PM
