Do you really need to remove the crank sprocket during cam swap?
Old Jan 11, 2004 | 12:56 PM
DRIVEFASTKEEPLEFT's Avatar
Im in the middle of doing my cam swap and have the cam out. On shoebox's site, it says to remove it and the renstall it. Is this to get the timing chain back on? any help would be great.
Old Jan 11, 2004 | 01:03 PM
1996 | Z28 SS's Avatar
Remove the crank sprocket? I don't think so... I've never done a cam swap on an LT1 of course, but I've Re&Re a camshaft on blocks that are on an engine stand. The crank sprocket was always on, never came off. You sure it didn't say cam sprocket?
Old Jan 11, 2004 | 01:07 PM
yes, crank sprocket. Just making sure the new timing chain will go on no problems. Thanks for the reply
Old Jan 11, 2004 | 01:56 PM
QCKZ28's Avatar
Re: Do you really need to remove the crank sprocket during cam swap?
are you changing the timing set when you swap cams? it is highly recommended.....
jesse
Old Jan 11, 2004 | 02:11 PM
gb95zconv's Avatar
You dont have to remove it .
Old Jan 11, 2004 | 02:34 PM
FastZinTennessee's Avatar
I didn't have to remove it.
Old Jan 11, 2004 | 02:43 PM
the crank sprocket looks to be in good shape. Ill be doing a new timing chain though. Thanks everyone, just making sure.
Old Jan 11, 2004 | 03:13 PM
QCKZ28's Avatar
why not put on a new timing set while you have it tore down?
it would be good insurance.....
jesse
Old Jan 13, 2004 | 08:41 AM
Jesse_Boyer's Avatar
This Jesse agrees with that Jesse.
I did just the chain when I did my head/cam install and the new chain was fairly loose, if not looser than the old one. Reason: the sprockets will wear as well.
If you've got a 95, just go ahead and buy a Cloyes double roller. They are only 70...
If you're 94 and lower, conver to 95+ stuff so you can run the Cloyes chain.
Jesse
Old Jan 14, 2004 | 10:18 PM
Remove it to replace it, but otherwise no.
I just edited the page to alleviate any confusion.
chuyz28
Feb 19, 2015 12:50 AM
chuyz28
Jan 15, 2015 04:14 PM
Queens94z28
Dec 20, 2014 09:11 PM
chuyz28
Nov 25, 2014 11:14 PM
