Do stock pistons go in either way?
Old Jan 26, 2005 | 12:52 PM
Pasky's Avatar
Was putting the pistons and new bearings back on the rods and was wondering if the pistons can go on either way? Or is their a way to see which is top and which is bottom. It looks to me like it goes either way.
Old Jan 26, 2005 | 01:26 PM
TransAmGT's Avatar
Re: Do stock pistons go in either way?
HUH??!?!?!?
Please clarify what you are talking about? Are you asking can you turn them 180 degree's and it still be the same?!
Old Jan 26, 2005 | 01:44 PM
1stz28's Avatar
Never done an LT1 but every piston I have ever installed was marked on top to indicate the front of the engine and the rods were installed so the bearing tangs were on the outside or facing the side of the block the piston is in. I'm sure someone with some LT1 experience will chime in.
Old Jan 26, 2005 | 02:05 PM
hambone3441's Avatar
They do have a directional arrow on them....
Old Jan 26, 2005 | 02:07 PM
Pasky's Avatar
Hmmm, have to double check then.
Old Jan 26, 2005 | 03:25 PM
Pasky's Avatar
After looking over my pistons, I cannot find this mark your talking about.
Old Jan 26, 2005 | 03:34 PM
they should be there.....are these the stock pistons and if so have you cleaned the top of them. The marks are very hard to see if you dont.
Old Jan 26, 2005 | 03:44 PM
Pasky's Avatar
their stock from a caprice, their fairly clean, any pictures you can post?
Old Jan 26, 2005 | 03:54 PM
Compstall's Avatar
I don't think I've seen an engine that DIDN'T require the pistons to be clocked a certain way.
Old Jan 26, 2005 | 03:58 PM
Pasky's Avatar
ok, this has already been established....sooooo?
Old Jan 26, 2005 | 04:06 PM
marshall93z's Avatar
Old Jan 26, 2005 | 04:19 PM
Pasky's Avatar
Thanks, exactly what I needed.
Old Jan 26, 2005 | 05:19 PM
no problem...
Old Jan 26, 2005 | 06:29 PM
Soooo...turn 'em the right way and get on with it!
Old Jan 26, 2005 | 06:32 PM
Pasky's Avatar
That was posted before the indicator was shown to me. Its just annoyign when someone points out something that has already been discovered. Say for instance, "Hey, I broke my rear because of too much torque, where can I get a new one" and someone chimes in and says, "I bet you broke your rear from all the torque." Its just better off not to post redundancies.
