Do stage 2 lt1 heads out flow lt4 heads???
Old Sep 12, 2003 | 01:08 AM
Dans91's Avatar
Lightbulb Do stage 2 lt1 heads out flow lt4 heads???
LT1 Stage II Heads 2.02/1.56 with Hard Springs
compared to
LT4 heads stock, LT4 hotcam springs
__________________
Old Sep 12, 2003 | 01:14 AM
SVT Killer LV's Avatar
ill be first to say if I did it again.. I would have gone with ported LT4's... hands down
Old Sep 12, 2003 | 02:12 AM
AndyB's Avatar
Yes
Old Sep 13, 2003 | 07:02 PM
arnie's Avatar
Guys, what was the question? To answer the ?, ported (done well) LT1 heads will blow past oem LT4 heads. Stickin' my neck out, cuz don't know what you refer to as 'stage 2'.
Old Sep 13, 2003 | 07:58 PM
WheelmanZ28's Avatar
Yea really
It depends what is considered "Stage II Heads"
Flow numbers??
Tru, any LT1 heads with some port work will generally outflow LT4 heads stock. There isn't a great deal of difference between the flow numbers of the LT1 heads and the LT4 heads. One of the main benefits of LT4 heads is that they are aluminum instead of Iron.
Old Sep 13, 2003 | 08:49 PM
TA Dreaming's Avatar
wheelman LT1 heads are aluminum too.
Old Sep 13, 2003 | 09:10 PM
Z95m6's Avatar
like the others said, It all depends on what stage II means. I would say most peoples stage II's would win over LT4's.
Old Sep 14, 2003 | 01:17 AM
SStrokerAce's Avatar
So if the stage II's flow more than the LT4's that makes them better? All depends, you can always upgrade the LT4's later and get them ported. Those things will really flow 290-310cfm where a LT1 will be lucky to get to a real 270cfm. Depends upon where you are coming from.
Bret
Old Sep 14, 2003 | 02:27 AM
unTAmedLS1's Avatar
Why would you say they are better because they're aluminum....Any f-body LT1 heads are aluminum just not the b-bodies(impala,roadmaster etc..) Maybe the 93s were cast but I know 95-97 all have aluminum heads if its an F-body or vette
Old Sep 25, 2003 | 08:52 AM
PhoenixCIS's Avatar
my LT4 heads flow over 280
after a little help
Old Sep 25, 2003 | 09:13 AM
Kain's Avatar
:ugh:
Old Oct 1, 2003 | 02:54 AM
TreySpeed's Avatar
On permanent vacation
after a little help
so do my LT1's
Old Oct 1, 2003 | 03:53 AM
BES-383's Avatar
My LT1 heads flow 290+
Old Oct 1, 2003 | 04:01 AM
S.J.S.'s Avatar
So will someone enlighten us all....what is the real definition of "stage 2" heads? Stage 3 and so forth.
Old Oct 1, 2003 | 10:05 AM
Ai's Avatar
Ai
It's a made up term, because customers just dont know any better & like to talk about things they don't understand... like flow #'s etc
