do I need to worry about pushrod length when installing impala head gaskets?
Old Oct 7, 2003 | 11:50 PM
john-e-boy's Avatar
I am doing a rebuild on my lt1 and going with a lt4 head and intake. I am also using the inpala gaskets which are .020 thinner than stock gaskets, do I need to worry about the pushrod lenghts or are the standard size ok to use?
I am looking at a set of comp cam pushrods and want to make sure I use the the right lengths. The ones I am looking at are 7.200" long.
John
Old Oct 7, 2003 | 11:57 PM
PoorMan's Avatar
Summit sells various pushrod length checkers. I bought a "Trick Flow" brand one for 12 bucks. 7.200 is stock.
Jeff D.
Old Oct 8, 2003 | 12:02 AM
QCKZ28's Avatar
FWIW, i run impala head gasket, stock aluminum lt1 heads, xe224/230 cam, 1.6 SA rr, and i used the stock 7.20 pushrod.
but to be sure use a pushrod checker....
Jesse
Old Oct 8, 2003 | 01:48 AM
kmook's Avatar
Advanced Tech Moderator
What Jesse said.
If its .020 shorter than going to a 7.150 pushrod would be to short. Most likely staying stock is correct, but id get a checker to make sure.
HectorM52
Parts Wanted
Jan 10, 2015 09:01 PM
Jazsun
Dec 29, 2014 12:14 PM
thenewkid
Nov 27, 2014 09:41 AM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
