Do i need chromoly pushrods
Old Jul 5, 2004 | 12:54 AM
disco192's Avatar
Im going with EX612 springs, comp-r lifters, 1.6 comp pro mags, and LE2 heads.
I plan on spinning to ~6750 and currently have comp hardened pushrods. Do you think i need to step up to chromoly prods? I was thinking about the trickflow ones. Are the Comp chromoly ones any better than the trick flow ones?
THX,
Stu
Old Jul 5, 2004 | 12:57 AM
J's 82's Avatar
by hardened you mean the 28$ set, the anwer is yes.. I have seen three sets of those bent or broken over the past year in cars that had more than stock spring pressure and were spinning high revs..
for my head and cam install I went with the thunderracing pushrods, slightly cheaper than the CC ones but for some reason looked identical.. once you get into the 100$ per set range I feel there is not enough of a difference to worry about unless you want to buy different sets and compare weight..
Old Jul 5, 2004 | 01:30 AM
disco192's Avatar
The ones i am looking at are the Trick Flow 7.2" chromoly ones.
The link is Trick Flow Pushrods
Old Jul 5, 2004 | 01:45 AM
J's 82's Avatar
those will work fine..
Old Jul 5, 2004 | 03:27 AM
5.0THIS's Avatar
the way I look at it.... pushrods are the weakest link in the top end of the motor...... I'd upgrade to chromemoly just to be safe
Old Jul 5, 2004 | 06:27 AM
hvyss's Avatar
I have run the Trickflow's thru 3 setups and two motors in my Impala SS with no problems
HVY SS
Old Jul 5, 2004 | 06:40 AM
disco192's Avatar
Just bought some trickflow pushrods for $76.50 from summit.
Anyone need some standard hardened ones?
Old Jul 5, 2004 | 09:27 AM
TigerWoodsJr's Avatar
should have asked me friday, I bent a stock one into the shape of a question mark at the track spinning only 5k ;[
13qtr
Oct 28, 2016 08:11 PM
Nutty's96
Dec 21, 2015 06:25 AM
9t4lt4z28
Oct 2, 2015 10:28 AM
karpetcm
Sep 29, 2015 10:08 AM
Slayer
Aug 17, 2015 03:55 PM
