do i need 93 throttle body to use 700r4
i have a 84 700r4 and want to know how to install in my 94 trans am someone said i need a 93 t/b do i need anything else and what is the install hooking up linkages like i am useing a manual valve body so what does the t/b swap do because i am going to shift manualy
Yea, many will say the 94+ TB already has the provision for the detent (TV) cable, but I found that to be untrue.
I swapped in a 94 former A4 engine in a 93 A4 (Th700r4) and the stock 94 TB did not work. (didn't have the provision) So I just used the original 93 TB.
You will need to swap the bottom plate from your 94 TB to the 93 because the idle air control valve is different, but fortunately, it swaps right on. You will also need the 93 A4 cable bracket. Other than that, it should be pretty straightforward. Are you going to control the torque converter manually?
Originally posted by BES-383
Yes you can use your 94 throttlebody. You just need to get a
93 detent bracket. It will bolt right on to your 94 TB
now this is starting to get confusing. but anyways no tq converter will not be manual how and why would you do that?
i need the cable on right not throttle cable right? and the bracket and the 93 t/b right and what does this alow me to do kickdown?how to hook up speedo or will it work the same
Do you have a lock up converter?
If answer is yes, you can put a manual switch to lock up the convertrer when ever you want to in 3rd gear.. Sometimes car will go in and out of lockup at low driving speeds in 3rd gear. Switch will keep it locked up.
Go to your Chevy dealer and order a 93 detent bracket. This is all you need. It has an extra slot for your tv cable or kickdown. Speedo works the same.
You have to buy the bracket with the detent cable in it.
what year 700 is it i know you said '84, but there was 2 different ones in '84 one is '84, the other is a '84 1/2, they have different iput splines, (27, 30), im looking to put an '84 in mine s well, but im trying to figure out which tranny it is without taking it out of the '84 camaro...
i belive its a 30 spline i'll count them later.it is the later version of the 700 r4. so i ask for the bracket at the dealer. my bracket has two slots now so i will need one with three? i have a lockup converter where and how much for the lock up control
JEGS PART # 890-376600 About $70.00
Shoebox you are right. I have an aftermarket throttle body. Thats why the detent bracket bolted right up. We installed a 700r4 into a car with stock TB and had to weld a tab on for detent cable. Sorry for the confussion
Jul 4, 2005 05:00 PM
