Do I have a bad lifter?
Old Aug 12, 2003 | 09:30 PM
natZ's Avatar
My car has 75k miles on it. It just recently started making a lot more noise from one valve. The pushrods are straight and a valve adjust did not cure it. I've heard cars with worn lifters before that cause a little more ticking. My car at 3k rpm sounds far looser than anything I've heard before, a metallic warbling. Can a bad lifter cause that much slack? Before I pull the intake is there anything else I should look for? Thanks.
Old Aug 12, 2003 | 09:35 PM
WheelmanZ28's Avatar
A bad Lifterr would be more noticeable at higher RPM. Chances are your stock Lifters are worn, as mine were when i was at your mileage.
A good indication of bad Lifters is Vacuum pressure. If VP is all over the place and inconsistant, chances are u have a bad Lifter or Lifters
HectorM52
Jul 30, 2017 11:46 AM
mightymouse383
Jul 20, 2016 07:34 AM
Jasonz28camaro
Jun 7, 2015 09:14 PM
Jasonz28camaro
West South Central
Jun 7, 2015 09:12 PM
KamikaZ28
May 28, 2015 12:45 AM
