Distributor cap question
Old Oct 25, 2003 | 05:45 PM
SilverTA2813's Avatar
Can just a distributor cap go out? I am getting low rpm hesitation while daily driving. Mainly between 1k and 2k rpm. It also feels like it is lacking power. I double checked all the wires and they are fine. The spark plugs and coil are brand new. It is also not the distributor rotor or sensor because i replaced it when i did my heads and cam swap. I just left the older cap on it though. Would a bad distributor cap do this, and is there a way to check to see if that is the problem?
Old Oct 25, 2003 | 06:08 PM
Compstall's Avatar
Can't really test it. I changed out the rotor only over a year ago and haven't had any problems since.
Old Oct 26, 2003 | 06:12 AM
slopokrodrigez's Avatar
Sounds like your EGR is sticking. Do a couple of things. First disconnect the vac line to it and plug it. Take if for a ride and see what happens. While it's cool, push the diaphragm in by hand and see if it feels rough. Also check if for leaks around the gasket. You could also clean it or replace it (the valve that is).
You also want to be sure your throttle body is clean and replace the throttle position sensor if it has a lot of miles on it.
Old Oct 26, 2003 | 11:38 AM
The tps and tb are brand new. Also i had my egr deleted when i put my headers on.
Old Oct 26, 2003 | 10:58 PM
revtime's Avatar
The distributor cap and rotor can wear just like the old school ones can, its basically the same design as far as delivery of spark goes.
I replaced the opti at 135k and the cap and rotor looked awful.
I think I could have just replaced the cap and rotor but its just too much work not too replace the whole opti in my opinion.
Noenav
Mar 1, 2019 07:38 AM
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
brentbrowning01
Dec 3, 2014 10:36 PM
