disconnecting 02s..
Old Sep 22, 2005 | 06:35 PM
  #16
93camaroLT1's Avatar
Re: disconnecting 02s..
Originally Posted by Alvin@pcmforless.com
For what reason?
You where gifted with a sensor that dynamically adjust your cars fueling to keep up with atomspheric changes. What part of that is a problem that you'd like to get rid of?
well I've got about 4 decent reasons for why to get rid of them for my application:
1. I have 94-97 headers which the o2 bungs are too close to the trans. pan so I just plugged them (not a big deal, i actually got other o2 bungs, i would just have to drill into the headers and weld them in, but keep reading)
2. I want to run open headers.. this will be a problem since the o2s won't be far enough away from the end of the collectors to prevent false readings
3. I also intend to run 110 octane gas, which is leaded and will destroy these o2s within 50 hours
4. The 93 o2s will prolly not work properly anyway since they now will be too far down the collectors creating a issue with keeping them at operating tempretures.. meaning I would have to upgrade to heated o2 sensors to have properly functioning o2s.
Old Sep 22, 2005 | 07:47 PM
  #17
Alvin@pcmforless.com's Avatar
You have long tubes right?
They are the same 93-97. I've got them in my car with both a automatic and manual.. the o2's are in no different place in any model LT1 with long tubes. You will not have any clearance issues..
Ok, fair enough.. open headers.. I don't really understand why.. you'll probally be faster, quieter, and actually streetable with some sort of exhaust..
Also, fair enough.. Seems like your building a race car.
4. If you want to upgrade them you can do a simple heated O2 swap.. that way they will stay warm
Old Sep 22, 2005 | 10:22 PM
  #18
i dunno, they are groty 94-97 longtube headers. They are on the car and there is less than a 1/4" between the trans pan and the o2 bungs, there seriously no way i'd be able to use those bungs even if I wanted to. It's no big deal I could easily put in some o2 bungs either in the collectors I just can't see a practical reason to use them, besides the car running better in changing conditions, but then again I only really drive the car during the summer when its nice out.
Formula Steve
Sep 19, 2023 08:31 AM
Nayr
Mar 3, 2023 08:34 PM
95z_28_camaro_4_Ivan
Oct 3, 2015 07:27 PM
plattted
West South Central
Sep 7, 2015 02:45 PM
4586
Aug 22, 2015 01:09 AM
