Disconnected o2 sensors for leaded fuel to check if I have false knock, ok???
I can't find anyone that sells unleaded racing fuel so I can check if this knock is false or not. So I was wondering if I use leaded racing fuel, can I just disconnect my oxygen sensors jump on the highway and see if my knock goes away at WOT? or is this a bad idea, Can the racing fuel ruin something else? Can running WOT without the oxygen sensors hurt anything? I don't have cats by the way.
You can't just disconnect the O2 sensors. You have to remove them. The lead will contaminate them if you leave them in place. A small amount of leaded fuel probably won't destroy them, but you are taking a chance if you don't remove them.
When you disconnect the sensors, the PCM will stay in open loop. If the tune is good, and its been driven long enough in closed loop to fully develop the long term fuel corrections (BLM's) you may get lucky and it will run the same as it did with the O2 sensors connected. Potential problem is, you will be running in Cell 18 WOT, and previously, with the O2 sensors connected you might have been running in Cell 15. The differences in the BLM's between the two cells will affect the WOT A/F ratio.
djm_e22:
You might try adding some pure Xylene or Toluene (get it at a paint supply or possibly the paint dept at a Home Depot or Lowes) to your gas. I can't find my reference data but ISTR that they both have effective Octane ratings of about 110. So 1 gallon in a 10 gallon total would bump a 92 rating to nearly 94.
teal98
15
Sep 16, 2002 01:23 PM
danielbmx
Aug 27, 2002 11:11 PM
johnsocal
21
Aug 17, 2002 01:06 AM
SilverWS6
13
Aug 14, 2002 09:29 PM
newby
10
Jul 27, 2002 11:39 AM
