Disable brake! light?
Old Feb 1, 2004 | 01:20 PM
Kataklysm's Avatar
Is there anyway to disable the (BRAKE!) light? Accidently broke one of the connecters and now it won't go off.
Old Feb 1, 2004 | 01:53 PM
slopokrodrigez's Avatar
You could pull the stop/hazard fuse #6 in the I/P block but only during the repair. I wouldn't do it as a temp. fix. Unless you need a new bumper.
Old Feb 1, 2004 | 03:44 PM
BlackIce's Avatar
Are you talking about the one in your raised spoiler? I have a z28 but just switched spoilers and there was a connector right before the wire routed itself through the spoiler im guessing if you disconnected that it should turn off. Im not positive but thats what i would guess. I had to take the plastic peice off of the trunk lid, on the inside and it gave me acess to it. If that dosent work just take the buld out that would do it. Good luck.
Old Feb 1, 2004 | 10:09 PM
Kataklysm's Avatar
I mean the light on the dash, all the bulbs are working fine. One of the connecters to the ABS broke but I don't see any wires torn or pulled out.
Old Feb 2, 2004 | 06:54 PM
Kataklysm's Avatar
No ideas?
Old Feb 2, 2004 | 07:07 PM
Don't Look Back's Avatar
Worse comes to worse you can get into the dash and unplug the bulb for the brake light.
Old Feb 2, 2004 | 09:42 PM
jbird's Avatar
either that or fix it right and replace the broken connector
dluna333
15
Mar 13, 2015 12:30 PM
squarehead
Jan 15, 2015 07:02 PM
AlaskaZ28
Jan 1, 2015 12:30 PM
Red97LT1
9
Dec 17, 2014 06:13 PM
