Differential question
Old Oct 27, 2003 | 08:23 AM
5SPDCHK's Avatar
Question Differential question
I did a search and didn't find anything...
My dad asked me to ask you all how to remove the c-clips and springs out of the differential on a 94 Z. He needs to change the axle bearings and seals.
Thanks in advance.
Old Oct 27, 2003 | 09:13 AM
Mtrhds94Z's Avatar
Pull differential cover.
There's a 'pinion shaft' [not the PINION GEAR as in ring and pinion] that is held in place by a 'pinion shaft lock screw'
Take the lock screw out then the shaft slides out.. then [after taking the calipers and rear rotors off] you push the axle IN and then the C clips either fall off, or you take them off the inner axle ends..
Then pull axle out, and proceed with axle seal and bearing in the usual manner..
Not sure what springs you mean?
Old Oct 27, 2003 | 09:15 AM
5SPDCHK's Avatar
I don't know either. His email reads:
Ask the guys on z-28.com if they know how to get the springs and c-clips out of the differential.
Thanks. I'm going to send this link to him.
Old Oct 27, 2003 | 10:37 AM
Sweetred95ta's Avatar
Could be talking about the springs in the carrier. But they definitely dont need to come out to do what your doing.
Benji
Old Oct 27, 2003 | 12:06 PM
5SPDCHK's Avatar
Benji
I'll find out from him. Thanks!!
QuickSilver02
Apr 7, 2015 11:12 AM
737drivr
Feb 20, 2015 11:54 AM
NewsBot
Jan 29, 2015 07:10 PM
guionM
9
Aug 29, 2002 01:48 PM
guionM
18
Jul 11, 2002 01:45 AM
