differential
Old Feb 8, 2004 | 07:11 PM
Donohue96M6Z28's Avatar
differential
hey...my rear end is starting to whine..and someone told me all tha ti need to do is jus add more fluid...but they said that i would need to chang eit all out..cant i just add some fluid and some limited slip?? with out having to take of the housing and doing the gasket and everything...but im not sure how much diff fluid is actually in there.. so i wouldnt know how much to add..waht do u guys think?
Old Feb 8, 2004 | 07:20 PM
InjectedSS's Avatar
Re: differential
Do you have gears? Aftermarket ones? If so this is normal so just get used to it!
If not then just add 80W-90 non syn gear oil thru the filler hole on the rear end until it comes out the hole!
Old Feb 8, 2004 | 07:49 PM
BlackDog's Avatar
I would also throw in some Lucus gear oil.
Henson071
Dec 30, 2015 09:55 PM
Henson071
Sep 18, 2015 04:01 PM
95z_28_camaro_4_Ivan
Aug 25, 2015 03:59 PM
'02 Collecter TA WS6
Mar 13, 2003 02:16 PM
jimlab
Advanced Tech
14
Oct 20, 2002 04:02 PM
