Difference between waterpumps?
Old Feb 21, 2008 | 09:57 PM
94zgreenmachine's Avatar
I do believe there is a difference between water pumps on an f-body, corvette and caprice/impala. Is it where the hose attaches?
I am looking to switch over to an electric pump. I have a new GM pump with 1500 miles and would rather use an old pump rather than wreck a perfectly GOOD GM pump ( read NOT Autozone).
Old Feb 21, 2008 | 11:37 PM
Romero155's Avatar
I got a Meziere pump on mine and it runs great although its a good habit to watch the temp gauge just in case. Im pretty sure that the CSR units require some grinding to the water pump housing but the Meziere you can just slap on. Make sure you get an electric waterpump relay kit to make the wiring easier. I got one from painless and it works good.
Old Feb 21, 2008 | 11:44 PM
http://shbox.com/1/lt1_water_pumps.jpg
Old Feb 22, 2008 | 05:01 AM
Originally Posted by shoebox
Thanks, I was just on your site looking at the ss spoiler fix trying to locate the part number for the relay. I could have sworn you had a Radio Shack part #. In fact, I even had the relay but that was almost 3 yrs ago and never got around to installing it. I have since lost the relay and I need to get it fixed so I can install my linelock.
In all my searching for the relay part #, I overlooked the simple fact that you had the difference between waterpumps on your site. I have used the site several times . Thanks for the time to put all that together.
Old Feb 22, 2008 | 08:24 AM
96capricemgr's Avatar
If you feel like getting creative I think I have a spare housing or two, but they are b-body. I am not far away though so you could take a look.
Old Feb 22, 2008 | 04:48 PM
It couldn't hurt to at least look. I am in Canada right now, but should be home soon. If you want, PM me and we could see what we can arrange. If I can sort my car out right, maybe we can run them at the RSD at WIR. Broken comp r(s). I could only find the reatiner to the lifter and it was only one, but no noise. I haven't driven it since May. I never got to fixing it cause lately it seems I have traveled the world (US, Norway, Canada and Germany)for work, built a 2 1/2 car garage, my daughter was born and work a ton of hours for work. I will be starting on the car soon...... at least I tell myself that
Old Feb 22, 2008 | 07:44 PM
ssbowtie1's Avatar
Post up in the Parts wanted section or local board. Water pump housings aren't exactly a rarity so you should be able to get one to install your EWP on.
WobblySausage
Oct 7, 2015 02:44 PM
NewsBot
Sep 30, 2015 04:20 PM
SergheiS
Sep 29, 2015 08:56 PM
Bxlt1
Sep 29, 2015 03:18 PM
