difference between a I-H beam rod
Old Oct 12, 2006 | 04:45 PM
  #16
Dave89IROC's Avatar
Re: difference between a I-H beam rod
Originally Posted by Sweetred95ta
I can tell what everything is here, but WTH is that blue bottle thingy? Vacuum canister? Do you always buy a bunch of new expensive parts that need to stay clean and then set them on the concrete outside?
coolant overflow bottle, hasd a drain at the bottom as well
Old Oct 12, 2006 | 06:21 PM
  #17
Dave '97 Z28 M6's Avatar
Originally Posted by rskrause
As far as functional differences go, either cross section works fine if it's a good rod appropriately selected. The "S" shape rod or the "two piece" rod is to be avoided at all costs though!!
LMAO!!!
Old Oct 14, 2006 | 06:12 AM
  #18
blown383's Avatar
The H beam rods will require less clearancing if you're doing a stroker motor.
-B
Old Oct 14, 2006 | 06:30 AM
  #19
94_camm's Avatar
thanks for the info guys
Old Oct 14, 2006 | 08:22 AM
  #20
nick3's Avatar
i beams are rated around 500hp, and h beams are 700hp + on a small block (average rating depending on what brand)
Old Oct 14, 2006 | 09:01 AM
  #21
JakeRobb's Avatar
Super Moderator
Originally Posted by JakeRobb
Hehe... I've got a pic like that... I'll have to dig it up.
Found it!
Old Oct 14, 2006 | 07:31 PM
  #22
wrd1972's Avatar
Found it!
gnarly dude
Old Oct 14, 2006 | 08:08 PM
  #23
respectirocz's Avatar
you can't really rate a connecting rod by horsepower
connecting rods are limited by the mass of the piston, the speed of the engine and if the engine is driving the car or vice versa
you can destroy a connecting rod rated for 500hp, on a motor that makes 250hp, simply by reving it to 6500 in 3rd gear and drop it to 2nd gear
LeftoverChinese
Jan 14, 2024 03:03 PM
Drtryder
Apr 22, 2015 04:17 PM
drptop70ss
Mar 26, 2015 01:50 AM
D1SC383LT4
Jan 26, 2015 01:41 PM
Catmaigne
Dec 25, 2014 12:16 PM
