difference between a I-H beam rod
Old Oct 11, 2006 | 06:38 PM
94_camm's Avatar
How can you tell the difference between I-H beam rods?
Old Oct 11, 2006 | 06:42 PM
Dave89IROC's Avatar
Re: difference between a I-H beam rod
I beam and H beam, look at the letters, I beam is wide at the top and bottom, h beam is wide on the sides
Old Oct 11, 2006 | 06:58 PM
94_camm's Avatar
can u tell which wat these are?
Old Oct 11, 2006 | 07:12 PM
seawolf06's Avatar
Those are H-beam rods.
Old Oct 11, 2006 | 07:33 PM
Dave89IROC's Avatar
yup, wide on the sides
Old Oct 11, 2006 | 07:42 PM
seawolf06's Avatar
Wouldn't that actually be the front and back since they face the front and back of the engine?
Old Oct 11, 2006 | 07:54 PM
bowtiepwr's Avatar
>is that a Cloyes True Roller timing chain? so your going with an electric water pump?
Old Oct 12, 2006 | 01:00 AM
quickSS's Avatar
On this page are some good photos showing I beams and H-beams. And also lower down on that page it shows which ones have block and cam clearance "built" in, (compares big end shapes).
http://www.karl-ellwein.org/EllweinE...ingrodpage.htm
Karl
Old Oct 12, 2006 | 07:26 AM
rskrause's Avatar
Moderator
As far as functional differences go, either cross section works fine if it's a good rod appropriately selected. The "S" shape rod or the "two piece" rod is to be avoided at all costs though!!
Rich
Old Oct 12, 2006 | 07:56 AM
SS RRR's Avatar
Rich
Is that a sample of your collection of expensive broken parts?
Old Oct 12, 2006 | 08:45 AM
Sweetred95ta's Avatar
I can tell what everything is here, but WTH is that blue bottle thingy? Vacuum canister? Do you always buy a bunch of new expensive parts that need to stay clean and then set them on the concrete outside?
Old Oct 12, 2006 | 09:04 AM
rskrause's Avatar
Moderator
You are a cruel man
Rich
Old Oct 12, 2006 | 09:40 AM
Bersaglieri's Avatar
Rich
I think its your opti.
No seriously though nice work.
-Dustin-
Daniel6718's Avatar
is there a purpose for the differant rods? is 1 stronger? i hear h beams are better?
JakeRobb's Avatar
Super Moderator
Hehe... I've got a pic like that... I'll have to dig it up.
