Difference in '94-95 and '96-97 OEM lifters?
I see 2 different part# for the LT1 OEM lifters, 5234890 for '94-'95 and 17120735 for '96-97.
I read something about the newer ones have a different check ball or spring pressure....are those ok to use in a '95 application? I assume so since there should be no other differences, but whats the advantage of the newer higher spring pressure lifter?
Is there a part# for either one of these as a set of 16?
SpraydZ
Jun 7, 2016 01:44 PM
