Did you run cooler after an electric water pump?
Old Apr 9, 2003 | 09:29 AM
Gripenfelter's Avatar
After installing an electric water pump do you guys run cooler?
How much cooler?
Old Apr 9, 2003 | 10:59 AM
97FormulaWS-6's Avatar
well... that's variable.... with a 160* thermo... and reprogrammed fans it runs at 178 perfectly.. never get really any higher...
A Elec WP WILL make your car run cooler in typical city/stop & go driving.. but on the highway or long high RPM runs it may run the same if not a little hotter....
The Elec. WPs run a constant amount of coolent it never changes the rate except the thermo opening, thus with a 160 it's prettymuch always open.
Old Apr 9, 2003 | 11:43 AM
norcalstreet's Avatar
I have experienced a slight temp increase in stop and go traffic and idling. Not really much to be concerned with. A Meizier WP flows a constant 35 gallons per minute. At idle I think the stock one flows somewhere around 10 gallons. At idle or stop and go traffic I think it pushes the coolant through the radiator a bit too fast which reduces the amount of time the coolant stays in the radiator for cooling.
Old Apr 9, 2003 | 12:37 PM
dreamer1q's Avatar
Hey Grip....I have the power pads ready....PM me
Q
Old Apr 9, 2003 | 12:47 PM
Tommy'Z 6speed's Avatar
I now run 168 - 170 with a 160 degree thermostat. Before the WP it was around 185 degrees so, yes, I saw a significant decrease.
Of course during extended idle periods it will increase until the fans come on.
Old Apr 9, 2003 | 12:59 PM
K I run pretty damn hot so I think I'll stick to running my pusher fans on during idle.
Dreamer: Thanx dude!
Old Apr 9, 2003 | 01:16 PM
QUASARBLUEZ28's Avatar
I noticed no change after going to electric. Probably due to when I have the fans cuting in and off.
Old Apr 9, 2003 | 02:52 PM
94T56T-TOPDREAM's Avatar
def ran cooler for me. I have a 180 thermostat, and it doesn't even get hot enough to open sometimes. Especially cruising down the highway it stays below the first line.
BMX Dad
Jan 23, 2015 07:00 PM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
Queens94z28
Dec 20, 2014 09:11 PM
thenewkid
Nov 27, 2014 09:41 AM
