Did something stupid in my car and need help with the fix
Old Jan 9, 2004 | 06:50 AM
Formula03's Avatar
Angry Did something stupid in my car and need help with the fix
Ok i was out racing the other day and when we were lining are cars up i was too far ahead so i put it in reverse and backed up a bit well me being a dumb@$$ i forgot to put back into drive and when he said go i stopmed the the pedal and the reaend started hopping like a mother but didnt go any where so i layed off of it and put it in drive and it worked fine. I still have posi, it still shifts nice no problems except uh when its in park or neutral it acts fine but as soon as you put it in drive it starts vibrating like crazy and it does that from idle to about 3k then it acts normal but i know its broken somewhere
so what do you think it is. I thought maybe drive shaft or converter.
Old Jan 9, 2004 | 07:30 AM
IslandZ's Avatar
Sounds like a U-Joint to me.
Old Jan 9, 2004 | 07:35 AM
Brandon94Z28's Avatar
I think everyone has done the same stupid thing before. I just so happened to do it at the track. I drove around the water box and then backed up to get in the burn out area. Did the reverse burnout and then felt stupid for the rest of the day.
Brandon
sounds like it could also be a tranny mount
Old Jan 9, 2004 | 07:58 AM
Onyx LT1's Avatar
My first bet would be the tranny mount as well. Sounds like the same symptoms I had when my was gone. Just go easy through the gears until you get it changed.
Old Jan 9, 2004 | 08:06 AM
siberiankiss's Avatar
when my tranny mount broke it was fine other than when i started to accelerate and it sounded like everything in my engine bay was about to fall out...giant clunk every time the car moved....
Old Jan 9, 2004 | 08:33 AM
AxeGrinder30thZ's Avatar
Same here. Exactly as you put.
Old Jan 9, 2004 | 09:37 AM
Seal's Avatar
so u raced in reverse? :P
Old Jan 9, 2004 | 10:35 AM
RE AND CHERYL's Avatar
Good job! I told you R dosn't stand for RACE.
Old Jan 9, 2004 | 02:41 PM
flyinZ's Avatar
I take it u didn't win??? What type of car did u race?
I would say tranny mount too...I recommend a "Prothane" mount..
Old Jan 9, 2004 | 02:46 PM
importeater's Avatar
Old Jan 9, 2004 | 02:52 PM
SMOKINV8's Avatar
I'm not sure which would be worse... Doing that to your own car, or having to tell people what you did.
Old Jan 9, 2004 | 03:35 PM
Formula03's Avatar
It was 98 Gt and the second time we raced i showed him who his daddy was but even though i beat him i feel like i got beat because of how laud he was laughing.
So you think it is the tranny mount, Why does it go away at higher rmps?
Old Jan 9, 2004 | 03:41 PM
93Z286Speed's Avatar
it happens to the best of us had a similar thing happen and i ended up with the worst exhaust leak ever Header shook it self loose from the Ypipe
Old Jan 10, 2004 | 06:49 PM
BamaZ28's Avatar
Well,
Start from the easiest and cheapest on up
1) Visually check everything down there (u-joints, mounts, fuild leaks, driveshaft weights)
2) Feel for play in d/s and rear gears
3) Change tranny mount
4) Change u-joints
5) Change Driveshaft
If one step doesn't fix it, move to the next one
cmdeshon
Dec 27, 2014 10:06 AM
brentbrowning01
Dec 16, 2014 06:35 AM
ChrisFrez
Dec 15, 2014 03:09 PM
USAirman93
Nov 24, 2014 03:37 PM
squarehead
Nov 21, 2014 08:02 PM
