Did some more mods and SLOWER by a tenth?
Old Jun 21, 2003 | 12:28 PM
Timberwolf's Avatar
A little frustrating...
I pulled another 50lbs of weight out of the car, reduced rotating mass by 42lbs with the new tires and wheels (Pro stars...skinnies up front), added traction (ET streets out back), and tossed in a set of 1.6 rollers...
And I run a tenth slower....
what the hell?
60' was about the same (see sig) but best I pulled off was a 13.32 et
Old Jun 21, 2003 | 12:30 PM
96z's Avatar
96z
Weird, how was the weather? Same track?
Old Jun 21, 2003 | 12:31 PM
Timberwolf's Avatar
Same track, temps were within 5 degrees
Old Jun 21, 2003 | 12:42 PM
96z's Avatar
96z
what was your MPH?
Old Jun 21, 2003 | 01:18 PM
Timberwolf's Avatar
what was your MPH?
I don't have the timeslip right here, but it was in the high 103 range
Old Jun 21, 2003 | 01:31 PM
Z-RATED94's Avatar
Welcome to my world.
Old Jun 21, 2003 | 01:47 PM
atljar's Avatar
Idealy you want to spin a little comming out of the hole for best ET and best trap. Maybe on your old run you had the best possible launch with those tires, spinning just the right amount. Now with the ETs, you arent spinning at all, hurting trap? You gotta pull a better 60 than that with ETs
Old Jun 21, 2003 | 02:37 PM
Timberwolf's Avatar
yeah, I hear ya. Can't complain too much about the 60 with stock motor and converter, etc.
Old Jun 21, 2003 | 02:42 PM
Jon97Z's Avatar
Ditto! See my other post on this page.
Old Jun 21, 2003 | 02:44 PM
Timberwolf's Avatar
I don't feel quite so bad though after reading all the money you guys have into mods and bolt ons. I ran mine low dollar style
Old Jun 21, 2003 | 04:29 PM
rage366's Avatar
could your bigger tires have had a little too much traction for their own good? lots of traction=lots of friction=slowing down.
Old Jun 21, 2003 | 04:38 PM
Timberwolf's Avatar
Dunno...I had the fronts at 45psi, rears at about 20psi. the 26" tires don't look much bigger if at all then my 245s, but I haven't measured.
still seems like the rockers should have netted me a few hp, and the weight loss a bit of speed...
Old Jun 21, 2003 | 05:49 PM
red's Avatar
red
The ET Streets will add rolling resistance to the car over your street tires. That is usually more than compensated for by the reduction in 60' times. Since your 60' time did not drop I am not surprised by a reduction in ET. I am also going to assume you lost at least 1 MPH.
The only thing I can think of for the 1.6 RR's is weather changes. Even though the temp was close changes in humidity and barometric pressure will play a huge part in MPH. What you really need to look at is corrected altitude.
Old Jun 21, 2003 | 09:34 PM
pickerman's Avatar
mods
damn Timberwolf! I got a lot more sheet in my Z and I cant touch that time. In my book your doing a hell of a job. Pickerman
Old Jun 21, 2003 | 10:10 PM
jasons93z's Avatar
timberwolf, what all weight reduction did you do. Im thinking about doing some on my car.
