Did Some 95 Cars come with 96 Casting # Heads
I purchased a set of LT1 heads that are suppose to be off of a 95 F-Body. However upon checking the casting # which is: 12551561, it shows that these are 96 castings. Is there a chance that these heads could be from a 95 car??
Re: Did Some 95 Cars come with 96 Casting # Heads
you might look around and see if they have date codes. I know Ford use to cast the date they were made into the part. So if there is a date code and its in 96 or 97 you know you got f-ed.
