did my MAF die ???
Old Jun 13, 2005 | 10:45 PM
ericz28w's Avatar
did my MAF die ???
ok i was crusing up a hill in 4th about 3-4grand and car starts surgging and spuddering a bit, and the RPM's are all over the place- goin to like 1500 to like 5000 while the car is surrgin. so i pull over and it idles fine , for a lil while i milk it over to a parking lot, and it starts to idle weird, the motor revs it self up and down spudders,pops, while the R's are jumpin around still from like 600 to like 3 or 4 grand -junpin allover, i cant figure it out, my bro said MAF but i have no clue. so i need lots of help new plugs,wires, opti, fuel filter, throws 0 codes. so???
Old Jun 14, 2005 | 09:58 AM
OBE1 95Z28's Avatar
Re: did my MAF die ???
Unplug the MAF and she how it runs, the PCM will switch to running speed density mode.
Old Jun 14, 2005 | 08:04 PM
ericz28w's Avatar
well it runs alot better, not awesome but stoped spuddering, and shootin the rpm's all over the place. What does this mean, is my MAF dead, and my stock fans that havent worked for a year turned on with my MAF unplugged??
Old Jun 14, 2005 | 08:14 PM
OBE1 95Z28's Avatar
Could be just a dirty MAF. Buy some electronic cleaner spray from Radio Shack and spray the sensor wires. Carefully clean them as they are fragile.
Old Jun 18, 2005 | 06:08 PM
ericz28w's Avatar
well i swapped MAF's with my friend and car is still running like crap, so im stumped
Old Jun 18, 2005 | 10:02 PM
RENE95Z's Avatar
First thing that popped into my brain was "IAC." Do a search on how to remove and clean and see if that fixes your problem. Also, try pulling off the MAP sensor and clean it. When I had a similar problem, these two things fixed my problem.
Old Jun 27, 2005 | 09:03 PM
ericz28w's Avatar
Angry Re: did my MAF die ???
well turns out it was my optispark for the 3rd time since the new motor, well any way car was running awesome for an hour then i just about get home and i go to pass a car and car lost power slightly ,started stumblling a lil bit,then it goes downhill from there i get home and i dont have enough power to get up my driveway, car will hardly idle, i have checked all the obvious( spark plug wires, plugs, new fuel filter, ????? are the problems ever gunna stop?? well if any one has any idea of where 2 start please let me know, and i have it hooked up to datamaster, if u need 2 know any thing from that,
68camaroboltz
Oct 5, 2015 01:46 PM
Double aught
Oct 2, 2015 11:29 PM
Bxlt1
Sep 29, 2015 03:18 PM
KYWes
Sep 26, 2015 08:49 AM
