Did Mobile 1 discontinue their oil filter for LT1s???
Originally posted by ShelbyZ28
What is the part # for the K&N that fits a 97 Z. Is it HP-2002 like stated before? Thanks
Bryan
Bryan
Originally posted by Patman
flow is much more important than filtration.
I didn't know about the 3002. I normally used the Mobile1 so the K&N was more of an emergency, besides... after driving around several stores for a filter the 2002 matched up.
1st - I'm going to find WTF happened to Mobile1 filters
2nd - If no Mobile1 Filters are available.. then the 3002 is it for now on. I wonder if the 3002 is a truck filter?
Originally posted by Black_Z28
WHAT?!?!?! If that is true why even use a filter? Why not just throw a normal cottton sock on there with a glass cover to prevent oil from going all over?
Please correct me if I'm wrong experts, I'm just taking a stab at it
Bryan
autozone oil filter inventory
I done some research on autozone's website today and the mobil 1 filters were available by ordering and they showed the k and n filter in stock. This is according to their database, not an actual person.
So the saga continues.............................
The clearances in an LT1 are big enough that you don't need to be filtering out the 10 micron particles, as they aren't going to create very much wear. But if you put a restrictive oil filter on there, the engine won't be protected very well when you drive it hard and you need your oil to flow properly through it.
I ran into the same problem here in North Carolina, running a K&N filter.
the big azz 1" nut on the bottom of the filter makes it easier for installation in my application, I'm a little tighter than ya'll.
plus, they advertise the burst strength, kinda fuzzy warm feeling, since I have a melling high flow oil pump and peg the oil press gauge on fire up in the mornings..
keep us updated, I'd like to run a mobil 1 filter to see the difference, although these $30 oil changes are KILLING ME!!
plus, they advertise the burst strength, kinda fuzzy warm feeling, since I have a melling high flow oil pump and peg the oil press gauge on fire up in the mornings..keep us updated, I'd like to run a mobil 1 filter to see the difference, although these $30 oil changes are KILLING ME!!
Originally posted by scoobysnax83
hey you knew when you bought your car that you were buying a high maintenance vehicle... If you didn't get over it
Verified... it SEEMS that you can order online, but whether they still stock it at the warehouse is a different story. I've called and the people at the counter cannot order it... but it is still listed on line.
I went to 3 diff. autozones around here (houston, tx) and none of them carried it anymore the last store told me that they discontinued the item! Autozone was the only place around here I could find them oreilys and wallmart don't sell um. But wallmart does sell the moble 1 oil for 25bucks. They only come in the 5qt size though. About a month ago I only needed one more quart of moble one so my aunt went to walmart and raised hell w/ them for not having single quarts in 5w-30 so I got another 5quarter for $3 and something cents.
So I'm really not sure about the filter, I also now switch to the k&n! With the nice big damn bolt on the bottom!
