did the intake leak fix and now i have a check engine light and my fans are always on
Old Jul 10, 2003 | 02:58 PM
Mattsblowen95TA's Avatar
okay well my car was leaking oil bad so did pulled the intake off. i have it all back together and running. but now i have a check engine light on. when i start the car it goes off for a few seconds then the light comes on and the fans also come on at the same time. my fans are always on even if the car is cold. i have everything plugged in. i check all the vacum hose's to. please help.
Old Jul 10, 2003 | 03:21 PM
kirschman's Avatar
This is just a guess, but, check your connection and the wires going to the a/c compressor. Reason, fans usually come on when u turn on your a/c. Or, check connection at the AIR pump, that fuse also ties in with the fans.
Old Jul 10, 2003 | 03:52 PM
oldBones's Avatar
I second the air pump fuse had the same problem with mine.
Old Jul 10, 2003 | 04:38 PM
Compstall's Avatar
Also check your connection to the water temp sending unit. I broke mine off once and my fans ran all the time and got a light as well.
Old Jul 10, 2003 | 05:12 PM
Johnnynsac's Avatar
So if I were at the track and wanted my fans to come on and stay on to cool the car, could I detach that connection
I know, I know, I need the the fan mod.
Old Jul 10, 2003 | 06:42 PM
The fans come on because of the SES. Scan for the source of your problem.
Old Jul 10, 2003 | 07:06 PM
ZLT195's Avatar
I did headers and intake leak at the same time and had the EXACT same thing happen to me.
I would start the car and the check engine light would come on. Then the Fans would come on. It did that for like two or three days. I think when I put my MSD ignition in it went away and the only thing I could think of was that I reset the PCM by disconnecting the battery. But I know for a fact that I disconnected it before that to adjust my panhard bar so go figure. Give it a try and reset the PCM. You might not get lucky but I don't have the check engine light and my fans operate normal again also the MSD isn't hooked up so I know that installing it wasn't what fixed it either.
Z~
Old Jul 13, 2003 | 10:20 AM
okay well i got the car scanned what a pain that was having an obd 2 port and an obd1 car. well i got a mass air flow and a/c pressure code. it was the that the little metal tabs on the a/c and mass air flow sensor were bent. grrrrrrrrrrrr well i have it all fixed now thanks alot guys.
Old Jul 13, 2003 | 12:40 PM
Nothing like a good scan to help make your car feel better. Unfortunately, a lot of ailments are self-induced.
bfmv13trivium
Jan 14, 2015 09:57 AM
dirtybird81
10
Jan 6, 2015 09:31 PM
cmdeshon
Dec 27, 2014 10:06 AM
ro2207
Dec 4, 2014 06:18 PM
Jul 4, 2005 05:00 PM
