Did I do this right?
Old Nov 16, 2003 | 05:49 PM
Heatmaker's Avatar
Advanced Member
Exclamation Did I do this right?
Finally got the TES system installed...Asome
http://community.webshots.com/user/onebadfbodyz28
But, I was installing the SPEC... The Haynes manual says to torqe the Pressure plate bolts to 15foor lbs then turn 30 degrees ...I did this, but when I went to double check the torque specks the ratchet wouldn't click. So I turned it somore then it clicked at 15lbs then I twistd it 30 degress agaon..did I do something wrong? Shouldn't it of had held the torque specs the first time?
Old Nov 16, 2003 | 06:44 PM
kevmor99's Avatar
If it didn't click it sounds like you didn't put enough force on the ratchet...but only 15 ft. lbs you should've had that easy..
Old Nov 16, 2003 | 08:16 PM
gb95zconv's Avatar
Put some loctite on those bolts as well.
Old Nov 16, 2003 | 08:27 PM
WheelmanZ28's Avatar
I wouldn't really recommend that.
Just make sure u get the torque spec RIGHT one way or another.
If they are over tightened, they'll actually come loose faster. Make sure u check and make sure they are tight once a week or so. I forgot about them for a month, and when i did check, one bolt was so loose i was able to just grab it and pull it out.
Old Nov 16, 2003 | 08:47 PM
JordonMusser's Avatar
West South Central Moderator / Special Guest
LOL, wheelman, I think you two are mixing up the PP bolts and the headers.
on the PP, I go 30ftlbs or so. no loctite, never had one back out.
If you went 15, +30.. and then you checked again and it was below 15, you either messed up or the bolt is toast(abotu to break).
Header bolts, check them after about a week or so, then maybe once every other month. if dont properly, they wont back out after the first retightening.
