Diagnosing a bad Opti
Old Nov 8, 2006 | 10:17 AM
lifbcracker's Avatar
So I think my Opti went out, but im not sure. Im driving home one late night from work and i run through a puddle of water and my tires break loose. So i decided to have a little fun and kept spinning them (never over revved). All of a sudden *boom boom* backfiring like a mother, then it creeps to a stand still and wont start back up, it will stumble just a tad but wont start. I basically replaced everything on my car when i did a 383 swap except the opti. So now im not sure if it is my opti or what but my car wont start. Previously my car had been running top notch, except for when the fuse on my fuel pump blew and it got no gas, i thought this might be the case again, but its not - the fuse is fine and i can hear the injectors priming.
My question is: is there anyway to figure out if the opti is toast without pulling it off and checking the internals? I dont want to buy a new one, put it on and that not be the problem(cause i dont think you can return them).
Old Nov 8, 2006 | 06:44 PM
help
Old Nov 9, 2006 | 01:03 AM
playa7970's Avatar
try here http://shbox.com/1/4th_gen_tech1.html
Old Nov 12, 2006 | 01:59 AM
more help please
Old Nov 12, 2006 | 06:31 AM
davidarel's Avatar
Have you checked the computer for codes? It will give you a misfire code or an ignition failure code. My 95 went out about 2 months ago and it did the exact same thing as yours, minus the water. I would bet money it's the opti but you should check for codes before you start spending money.
Old Nov 12, 2006 | 03:51 PM
it will give me an ingition failure code even if the car won't run?
Old Nov 12, 2006 | 04:06 PM
1FstFormulaV8's Avatar
It might give you a light for low resolution. Could be a number of things. I'de have it checked for trouble codes. You don't want to go "easter egging" your car. That gets expensive! I'de test before I started throwing parts on.
Old Nov 12, 2006 | 05:26 PM
davidarel's Avatar
Yes, it will say "ignition fault 4x" or something like that. This basically means the opti unit is bad and it isn't just a burnt rotor.
beltrunner
May 17, 2015 10:18 PM
BLK1997Z28
May 7, 2015 03:01 PM
ad356
Apr 11, 2015 11:12 PM
USAirman93
Nov 24, 2014 03:37 PM
