Diagnosing a bad lifter.
Old Dec 9, 2004 | 07:47 PM
94 TEALBIRD's Avatar
My car is getting a tap out of the drivers side valve cover, and the computer is sensing knocks and retarding the timing. I readjusted the rocker arms and everything felt good, but the noise is still there and timing is still getting retarded. How can I diagnose if I have a bad lifter with out taking everything apart. Or does this sound like a problem in the head? Thanks in advance for any help.
Old Dec 9, 2004 | 08:23 PM
TigerWoodsJr's Avatar
Re: Diagnosing a bad lifter.
sounds like a bad lifter and you better not run the car anymore and pray it didn't eat the cam...unless you want that...
Old Dec 9, 2004 | 08:35 PM
ABA383's Avatar
Pull the valve cover and start the engine (I know this is a little messy) Try to isolate the lifter by listening through a piece of hose or whatever way you prefer. Tighten the rocker arm nut slightly (1/2 turn or so) and see if noise goes away. If a lifter is bad usually the tap will go away for a second and then slowly return (about as long as it takes you to straighten back up after bending over in the engine bay)...Good luck...
--Alan
Xiantyl
Jul 21, 2015 05:42 AM
Jmj93z28
Jul 10, 2015 06:37 PM
Boss002
Jul 9, 2015 03:33 PM
colts0455
Jul 8, 2015 12:21 AM
colts0455
Jul 7, 2015 07:19 PM
