Dexcool
Old Jan 25, 2004 | 06:34 PM
ollie-99's Avatar
Dexcool
anyone not use it on there car? like go w/ water wetter or anything like that?
just wondering
Old Jan 26, 2004 | 12:12 AM
johnny o's Avatar
I think you can use water wetter with dexcool and dexcool keeps things a lot cleaner then normal antifreeze does. A company called Evan's makes this stuff NGP+ or something? You might want to check that out. It is a waterless antifreeze and is a lot better then dexcool with aditives.
Old Jan 26, 2004 | 12:22 AM
Jason Dove's Avatar
Ollie, I run the green stuff in my car. Came that way when I bought it used from GM, so I keep running it.
I don't bother with water wetter or anything, along with the Meziere and the 160 stat, cooling sits at about 80 Celcius.
Old Jan 26, 2004 | 02:17 AM
InjectedSS's Avatar
Yea dexcool is the $hit, don't waste money on that watter wetter crap. Who cares, just keep your antifreeze changed often and you don't gotta worry about it. My car NEVER get's above 180. I have made it cooler by programming the fans lower but 180 is plenty!
Old Jan 26, 2004 | 03:06 AM
DrewHMS97SS's Avatar
dexcool turns into jelly. use the green stuff. You should have seen my block when i pulled the motor. OMG. i have flushed the system twice since i bought it too. 30k on my end.
Old Jan 26, 2004 | 03:11 AM
GhostZ's Avatar
Fallacy...it's only going to gel if you use highly silicated "heavy duty" green coolant like that which is used for heavy duty diesel applications.
Old Jan 26, 2004 | 03:15 AM
InjectedSS's Avatar
I see stupid people Guess all the testing that they do that proves dexcool is better just doesn't apply to your engine. Guess that the laws of physics sease to exist in your block
Old Jan 26, 2004 | 08:10 AM
Eliminator's Avatar
I put in the green, Had Dexcool in my Blazer it got this crusty stuff build up in my radiator cap so I had it flushed and the green put in never had a problem yet.
Old Jan 26, 2004 | 10:52 AM
Brundle's Avatar
can we play name that movie(s)?
Old Jan 26, 2004 | 11:44 AM
lazygearhead's Avatar
Im gonna have to respectfully disagree with you. I do agree that it is a great coolant while it is not jelly, but I have had 3 vehicles with which I have run nothing but dexcool (and I do all my own work, so I know what's been in it), and about every other year (one is a 95, the other two are 94s) I had to totally flush the system because it has become clogged (heater core clog was most common). Now Im a gearhead, and dont mind working on my car for the sake of working on it. I dont mind repeating jobs on it. But this is my project car. I do mind repeating jobs over and over again that are not necessary for my (and my family's) daily drivers. That is why in 1999 we switched to the green stuff and have not had a single problem. I cannot say those tests were wrong, but I can say that they probably were not complete, cause I know me and my 3 cars are not the only ones with this issue.
Old Jan 26, 2004 | 12:38 PM
InjectedSS's Avatar
HAHA and you know this
Old Jan 26, 2004 | 12:50 PM
maybe read some other posts before trying to ridicule other people. its not just me jack ***.
ATMINF's Avatar
I run dexcool in my car and it has been fine. I also run water wetter and it don't hurt ether. As for thr coolent jellying up, I have seen this happen, but only on cars where the coolent got contaminated. When the dexcool first came out people said it was okay to mix the green and orange stuff, but now it seems that is not the case. And this is what happened to the the cars that I saw. The two types were mixed and after some time the coolents started to jell.
Also for me I have flushed out my coolent every two years and have had no problems with the dexcool. When I torn my engine apart almost a year ago(the motor had over 114,000 miles on it and its a 1995) the water passages looked brand new. I had no rust, slag or crap in them at all. So I would say that as long as you flush your coolent system every two years or so you will have no problems with the dexcool "jelling-up". Also another advantage of the dexcool is that it contains far less silicants in it and this in turm increases the life of the seals and waterpump. Hope this helps.
Old Jan 26, 2004 | 01:29 PM
95BlackTA's Avatar
I KNOW I KNOW- MY COUSIN VINNY!!!!!!!!!! Funny stuff
Old Jan 26, 2004 | 02:10 PM
Zachz28's Avatar
Well i dont know which is better but i have been told that if you mix them they can create an acid that starts to eat away a stuff. I am sticking with the stock ethel-glycol.
