descreen the map sensor
Originally posted by americanmusscle
There is mixed reviews on this. Your best bet is to leave it alone or you might have a big stumbleing problem because of it. Just get a granatteli (sp?) mass air flow.
I descrened mine, and it runs fine, i forgot to mention that above.
I have had a few talks with Bryan Herter at Pcmforless and he says that the only harm in taking the screen off is debris getting in there and destroying the wires, but if you have an air filter this will not happen. He said to not port the Maf because it will make it hard to tune and throw off its readings.
Originally posted by 95Z28ConvertCam
I heard it was ok to do as long as you still had the air filter in
I'm obviously not a proponent of removing it. I had mine out for a while but thankfully saved it and reinstalled. FWIW, I felt no difference with it out and saw many potentials for problems, thus why it went back in.
If you do it, fine, but be careful and save the screen so you can put it back in.
It's not bad to mess around with stuff, but at least try to know what it is you are messing with.
My $.02 anyway.
sleeperZ96BT
Sep 9, 2015 08:28 AM
350350
14
Aug 11, 2015 12:03 PM
whitehooptie
Aug 10, 2015 07:02 AM
zajones
Jul 30, 2015 02:18 PM
Noct
Jul 14, 2015 01:18 AM
