Derivative Engine??
Old Jul 27, 2006 | 10:15 AM
"White Knight"'s Avatar
Derivative Engine??
What the heck is a derivative engine?
Is the LT1 engine a derivative engine??
Old Jul 27, 2006 | 10:20 AM
Re: Derivative Engine??
I did some searching on Google and all I come up with are Military Jet fighter data. The one thing I found was this.
"A common intermediate solution is to develop a
“derivative” engine. A derivative development starts with an existing
engine and changes components and controls to “derive” an engine
that meets the new requirements. In some cases, derivative engines
are simply “growth” versions of their predecessors that are intended
for use in the same aircraft to accommodate increased mission requirements
or to compensate for increasing aircraft weight. In other
cases, a derivative engine may be so different from the original engine
that its commonality with the original is outwardly indiscernible.
Derivative engines are built around a previously designed engine’s
core (sometimes these cores are also enhanced over their original"
So basically an engine based on an engine? Is that all it is?
Old Jul 27, 2006 | 10:42 AM
ChevalierSS's Avatar
I've never heard of the LT1 called a derivative engine... but by definition it is a derivative of a standard SBC. The LT1 is practically a SBC, but modified for reverse cooling, gear driven water pump, normal distributer replaced by the opti
Old Jul 27, 2006 | 11:05 AM
atljar's Avatar
And then the LS1 is a derivative of the LT1.
Who's your daddy now!
Lol
Yea, I had just never seen this terminology used before.
Old Jul 27, 2006 | 02:07 PM
97WS6SCharged's Avatar
Not quite. The LS1 is totally different. Now the LS2, LS6, LS7, etc... are all derivatives of the LS1.
Old Jul 27, 2006 | 03:47 PM
deputydough's Avatar
lt4 and lt5, on the other hand.............
Old Jul 27, 2006 | 03:53 PM
ah, I get it now.
Old Jul 27, 2006 | 04:26 PM
LT5 has more in common with the LS1 than it does with the LT1.
Old Jul 27, 2006 | 05:23 PM
...or maybe with a boat motor...
Old Jul 27, 2006 | 06:05 PM
Or a Lotus sports car?
willismoons
Feb 14, 2015 08:42 PM
STR FTR 1
3rd Gen / L98 Engine Tech
Feb 10, 2015 10:36 PM
Injuneer
Advanced Tech
Jan 15, 2015 02:49 PM
Caps94ZODG
22
Jul 30, 2002 08:45 AM
