Denatured alcohol, smog/aircare test
Old Jul 9, 2007 | 11:10 PM
94Zman's Avatar
Hey guys, having some smog / aircare test hassles even with fairly recent tune-up a new Magnaflow cat. Seen a few old posts about running a bit of denatured alcohol just before the test.
Does this help bring down hydrocarbons and any adverse effects on the car afterwards?
Thanks in advance !
After a good thrash, with mohawk ethanol based gas, drive test only;
Hydrocarbons HC limit, .50, 1.20 score, fail
Carbon Monoxide, 9.32 limit, 3.66 score, pass
Oxides of nitrogen, 1.24 limit, 1.12 score, pass
Old Jul 10, 2007 | 07:43 PM
96capricemgr's Avatar
I would sooner get a gallon of E85 if you can, denatured is basically ethanol but I do not believe it is as "dry".
Old Jul 11, 2007 | 11:19 PM
94Zman's Avatar
Thanks, seems its not so easy to fine. Methyl hydrate is, but don't here any good comments about it....
Old Jul 24, 2007 | 09:38 PM
94Zman's Avatar
Well adding ethanol did nothing, but a fixing vaccuum leak sure helped, Hydro carbons pass, CO pass.... Nox fail, but it looks like a faulty EGR ..close....
Formula Steve
Sep 19, 2023 08:31 AM
Nayr
Mar 3, 2023 08:34 PM
Aaront810
Aug 29, 2020 09:34 PM
greenzee28
Sep 25, 2015 04:29 PM
jackpawt883
Sep 10, 2015 08:53 PM
