Delteq ignition question
Hey guys,
I just installed the delteq system after my car wasn't running correctly. It seems, at times, to have the same problem after installing the delteq, new plug wires, and new plugs.
But, after disconnecting the battery to reset the pcm, it runs perfect. Only later on in they day after it cools off it runs bad again, very rough idle when I start it, sounds like it's missing a cylinder, runs horrible.
This has to be the weirdest problem yet with this car. After countless manhours, there has to be a solution.
I'm almost ready to ditch the stock pcm and go accel.
There are no trouble codes.
Thanks,
Ed
Thanks,
Ed
lbrowne
Nov 13, 2011 04:25 PM
