Delteg Install.....
Delteg Install.....
Alright i said i would make a post on the delteg system. Right now i am in the process of putting the wires on. I got frusrated last weekend and gave up on the wires. The installing the coil packs is super easy---basically it's just a spark plug wire job. I did at least finish the 3200stall converter. I really hate doing wires on these cars. So anyway maybe this weekend i will get her all patched up and make a run and see how i like it. It will probably be hard to tell with the stall and the delteg being both installed at once, but i will at least see if it starts easier and doesn't miss way up high. I'll keep you guys posted on how it's comming and how i like it.
O yea and also there was a problem with the valve cover mounting bracket. The center bolt holes don't line up with the holes in the valve cover. I had to drill out a 1/4" hole right beside the other hole and grind a little so the bolt would sit flush with bracket. I was wondering if anyone else had this problem. I plan on calling the company and finding out for myself if i don't hear of other people having this problems.
