dash light ?
That is the low coolant light. Check the coolant and if its not low, most likely the sensor went bad. A common accurance. The sensor is on the top passenger side of the radiator. If you unplug it, the light will go out or you can replace it like I did.
Magenta_Hearts
Mar 29, 2017 08:54 PM
fpete1992
Dec 11, 2014 03:51 PM
