Daily driver: which electric water pump?
I sent a bad pump in for repair, they jerry-rigged it and sent it back. The impeller scraped loudly against the housing and immediately sent aluminum filings across my workbench upon testing it. They didnt even test the pump before sending it back.
So they said they would arrange to have it picked up. Instead of waiting around for a pickup, I asked if I could just ship it out and be refunded the shipping cost. The lady said this was fine, then later refused to refund the shipping cost. Btch flat out lied to me and swindled me out of the shipping costs, and has stopped responding to my emails. Who the hell does that? Total downtime was around a month, thats rediculous. I wish I would have gone with Meziere.
It's possibly overkill as my car never ran hot with the CSI pump @ 37gpm. However, the HD meziere pump has approximately the same flow rate as the stock mechanical water pump and that was the reason that many people shied away from electric setups......
One of the biggest reasons stated for those opposing the use of electric pumps is the flow rate at maximum.....
By the way, the engine driven pump usually runs much lower rpm than 2500...it spins at cam speed (1/2 engine speed)
An electric pump should provide several times more flow at idle when the car isnt moving and is most prone to overheating.
You're also right about higher flow at idle with an electric pump. We aren't argueing at all.....I'm just stating what those that oppose the use of an electric water pump have been saying for years....
http://www.ws6.com/mod-14.htm
Electric frees up power by not being driven off the Cam Shaft not because it moves less water which in fact it doesnt move less water.
Dyno Results of Electric Water Pump
Larry
Copied this from another thread.
couldn't find a spare water drive laying around, but if you have the time to count teeth:
I "think" I got them all:
39 teeth on the Water Pump drive unit
99 teeth on the cam drive sprocket
2.538:1 ratio between water pump and cam. (99/39)
2:1 ratio between cam and crank (any 4-stroke)
1.269:1 ratio between LTx water pumps and crank.
11 GPM @ 1,000 pump RPM (787 crank RPM)
20 GPM @ 2,000 pump RPM (1576 crank RPM)
31 GPM @ 3,000 pump RPM (2364 crank RPM)
40 GPM @ 4,000 pump RPM (3151 crank RPM)
51 GPM @ 5,000 pump RPM (3940 crank RPM)
64 GPM @ 6,000 pump RPM (4727 crank RPM)
which is right on par with what the road racer's are seeing... GPM starts to drop due to cavitation above 6000 rpms... or 7615 pump RPMs.
One solution I guess could be a new cam sprocket and water pump gear that reduce the ratio closer to 1:1 ratio between crank and pump RPMs... but then you risk really low flow rates at idle (and good luck getting anyone to invest in tooling for such a LT1-specific piece)
e-pump is fine for everything but sustained (several minutes) high-rpm racing... a second inline e-pump and thermostat delete would be in order at that point. But really, this is in extreme examples only.
