Cylinder head banjo bolts
Old Feb 3, 2005 | 11:03 PM
$hawn's Avatar
Should I put any thread sealer or teflon tape on the threads to those banjo bolts on the back of the heads. Or should I not put anything on at all.
Old Feb 3, 2005 | 11:05 PM
Smokn '94 Z's Avatar
Thumbs up Re: Cylinder head banjo bolts
Yes you should. I put teflon sealant. All Good...
Old Feb 4, 2005 | 07:30 AM
sleepy_z28's Avatar
"Yes you should. I put teflon sealant. All Good..."
Hmmmm, that's interesting. I've never done that to mine. I have put a real light coat of RTV on the sealing washers before so they wouldn't be damaged when torqued down and reseal better. I'm sure it doesn't hurt to put the teflon on there though.
Old Feb 4, 2005 | 07:49 AM
Hmm...I didn't put any RTV on the seals and don't think they need it.
Looking at how it all works, the round seals do all the sealing, so thread sealant really has no purpose in this case, IMO.
Old Feb 4, 2005 | 07:54 AM
bowtiepwr's Avatar
>The sealant shouldn't be required since there are 2 seals sandwiching the banjo bolt they are rubber and should keep the sealant from leaking through the threads , but would it hurt to put some sealant on the threads ? why not do it ?
Old Feb 4, 2005 | 07:58 AM
GUMP's Avatar
I would not put any kind of sealant on the threads. If you block the holes you might create hot spots in the heads. If you are reusing the washers, a little rtv will help.
Good Luck,
Daren
Old Feb 4, 2005 | 08:09 AM
Loadre's Avatar
Never used sealant on mine and they're doing great.
Old Feb 4, 2005 | 04:16 PM
Lightbulb Re: Cylinder head banjo bolts
I did it more as a lubricant than a sealant. I had a hard time getting mine apart when I did my heads and cam and had no access to neverseize at the time of re-assembly so I knew it won't hurt and can only help. I basically stripped the head of my banjo bolt trying to take it off so the teflon sealant should prevent that from happening to me again. But everyone is right, now that I think about it. Those are seals already with the bolts. Actually if you want to do it right they should be replaced with new ones.... Still don't think it hurts any to use it...
Old Feb 4, 2005 | 04:29 PM
sleepy_z28's Avatar
"I did it more as a lubricant than a sealant."
Exactly what I was getting at.
Old Feb 4, 2005 | 04:54 PM
BUBBA's Avatar
What's a bango bolt and why?
Old Feb 4, 2005 | 06:19 PM
A bango bolt is a banjo bolt that is mis-spelled. I am not sure why.
Old Feb 4, 2005 | 11:13 PM
$hawn's Avatar
I got all new bolts and seals, but yeah the seals should keep it sealed now that I think about it. Thanks guys.
oldschool
Feb 9, 2016 09:21 PM
maybe2fast
Mar 16, 2015 09:45 AM
Chris Anderson
Jan 27, 2015 08:30 AM
thenewkid
Nov 27, 2014 09:41 AM
Elcojoe
Nov 17, 2014 10:27 PM
