Cylinder 1 misfire help please......
Old Apr 12, 2003 | 04:50 AM
drewstealth's Avatar
My car had a misfire on it. It still had the stock plugs and wires, so i decided to change the plugs and wires. The service engine soon light was on so i had the shop scan it. It said that cylinder 1 and 8 had a misefire. So I put in accel 9000 wires and autolite platinum plugs. It got rid of the cylinder 8 misfire but the cylinder 1 misfire seems more noticable now. I hooked up a timing light up to the cylinder 1 wire and it had power. I have no idea what it can be. Do you think it can be my fuel injectors being clogged? Or would a clogged fuel filter cause just 1 cylinder to misfire? I'm hopeing something isn't wrong with the engine because i just bought the car 1 month ago, and already had to replace the clutch. Any advice would be extremely appreciated.
Old Apr 12, 2003 | 09:05 AM
96WS6TA's Avatar
I would guess it is probably ignition related. A clogged fuel filter would effect all the cylinders. It could be an injector however. You could swap your #1 injector for another cylinder and see if the misfire follows the injector. They are pretty easy to get at. If the problem is still cylinder #1, I would do a compression test on it to make sure you don't have a compression problem. The first thing I would look at though is the plug and wire to make sure that is not the problem. Good luck!
Old Apr 12, 2003 | 11:27 AM
Well for cleaning the injectors do you think those little bottles you buy at autozone that you poor into your gas tank would work. Or would i have to take it to the shop so they can do that fuel injector clean thing to it.
Old Apr 12, 2003 | 03:11 PM
TTT
Old Apr 12, 2003 | 11:07 PM
Well i did a compression test on the #1 cylinder and it read 165. I took out the plug and it had good a good spark. So what other things could it be? Do you think it would be my opti? Or should i take it to the shop and have them do the fuel injector cleaning thing?
G-BODYT56
Jan 14, 2022 11:14 PM
Jeff1904
Jun 5, 2016 05:00 PM
93 RedBird
Nov 15, 2015 08:24 AM
94Maroz28
Oct 27, 2015 04:38 PM
jayblev95
Sep 26, 2015 09:44 PM
