Cutting Vortec Elbow
Old Jan 10, 2006 | 05:35 PM
TheBiz's Avatar
I've done a search on here and it hasn't turned up much. What are you guys using to cut the divider out of a Vortec elbow? I can get to some of it with am air saw, but its getting tricky. Any info would be great. Thanks in advance.
-BIZ
Old Jan 10, 2006 | 09:10 PM
Sleeper_Z's Avatar
Re: Cutting Vortec Elbow
Id just go at it with a die grinder or a dermel tool. Then smooth it out with a 36grit roll and work your way down to a smoother grit.
Jeremy
Old Jan 11, 2006 | 01:06 AM
9T4Z28's Avatar
What is the purpose for cutting the divider? When i bought my car it had the Vortec elbow, just curious, maybe i should do it too?
Old Jan 11, 2006 | 01:23 AM
oneslowz28's Avatar
less resistance
Old Jan 11, 2006 | 10:04 AM
97WS6SCharged's Avatar
Save yourself a ton of headaches and buy the trickflow elbow.
Old Jan 12, 2006 | 08:26 AM
TheBiz's Avatar
I found this one for pretty cheop, thats why I am still working with it. The reason I am cutting it out, is due to my nitrous setup. I am putting the nozzle at the end of the elbow before the divider starts, I'm affraid the divider will give me an un even spray. I'm gonna go at it with a die grinder today.
Old Jan 12, 2006 | 09:39 AM
It all ends up in the same place. You could install a nozzle on each side of the elbow.
Jeff1904
Jun 5, 2016 05:00 PM
colts0455
Oct 4, 2015 09:47 PM
football4life
Oct 4, 2015 07:48 AM
Hal Fisher
Sep 30, 2015 09:03 PM
