Cutting/Shaving New Poly Motor Mounts
Old Oct 6, 2006 | 08:25 PM
ponyackn's Avatar
Question Cutting/Shaving New Poly Motor Mounts
Where exactly do you the motor mount? I have the Energy Susp. motor mounts and I don't want to hack them up too bad. I see that one mount is too big in the clamshell (the clamshell shaped like a large triangle). Do I shave the top of the mount? If so, how much?
Old Oct 6, 2006 | 08:30 PM
JimboManJones's Avatar
Re: Cutting/Shaving New Poly Motor Mounts
When we did motor mounts in my friends 94, we didn't do anything like that. I don't remember what the shells were shaped like.
Are you sure you have the right mounts in the right side and in the right way?
Old Oct 6, 2006 | 09:01 PM
ponyackn's Avatar
Yes, I'm sure. I have searched and have seen a couple posts that briefly mention cutting but not in detail. The posts mentioned cutting the corners of the mount but I don't see why they need to be cut, it seems that the top needs to be shaved.
Old Oct 6, 2006 | 09:59 PM
Dennis93TA's Avatar
I just did mine a few weeks ago. I didn'y have to shave the shell. I did have to trim the poly though. I put them on and then lowered the engine and trimed as necessary with a drimel.
bowtiepwr's Avatar
>I also have the Energy Suspension motor mounts, but I don't remember modifying them, but I also have the BMR K member... wonder if that has something to do with it
Old Oct 7, 2006 | 08:52 AM
97WS6SCharged's Avatar
Ditto. Mine went right in.
Old Oct 7, 2006 | 09:41 AM
LT1_383's Avatar
I had to modify the passenger side a little. The poly was sticking out too much to get the mounting bolt in the hole so i had to trim the top corner a little. I ended up swapping back to OEM a year later anyway. The poly shrunk and ended up being loose in the clamshell making my header hit my steering shaft again.
Old Oct 7, 2006 | 10:20 AM
z96's Avatar
z96
I have them also never had to modify anything . i had to use a vise to squeeze shut one of the shells that about it
Old Oct 7, 2006 | 12:35 PM
irishz28's Avatar
the way i did it is, i clamped the shells and tacked a few welds on it and i dident have to cut anything.
Old Oct 7, 2006 | 04:12 PM
gillt1's Avatar
Hi,I left all bolts loose until I had everything lined up ,then began to tighten,then lowered motor ,worked out great GOOD LUCK
Old Oct 7, 2006 | 05:24 PM
CamaroSS30thAnn's Avatar
i had to shave a little of the mount in the corners for the bolts to go on but other than that i had not problem
HectorM52
Jul 30, 2017 11:46 AM
Jason Short
Jan 19, 2015 06:34 PM
DubbyZ28Camaro
Aug 4, 2002 12:53 PM
rpm4lalo
Aug 3, 2002 02:35 PM
