cutting out at WOT
Old Jan 21, 2006 | 08:49 PM
EliteSpeed's Avatar
cutting out at WOT
94 bone stock auto, when I am at WOT it almost acts as if it is hitting the rev limiter but yet its not. It usually happens around 4800 and will not go any further until I lower throttle. I just did a plug wire tune up, and it still does it. Is there a common problem that might solve this?
Old Jan 21, 2006 | 08:54 PM
Z28WannaB's Avatar
Re: cutting out at WOT
Check your fuel pressure.
Probably bad pump
- Z28Wannab
Old Jan 21, 2006 | 09:11 PM
got8?'s Avatar
Like said above probably a bad pump check you fuel pressure.
Old Jan 21, 2006 | 10:20 PM
CamaroSS30thAnn's Avatar
damn they got here b4 me , haha , also check backpressure, could be a cat. does the car feel really lazy off the line or at WOT?
Old Jan 21, 2006 | 10:23 PM
amean94ta's Avatar
did you do plugs also? gap them right? stock heat range?
Old Jan 22, 2006 | 05:37 AM
bowtiethunder's Avatar
could be the coil
Old Jan 22, 2006 | 07:24 PM
87lt1rx7's Avatar
If the fuel filter is still good and your plugs and wires are pretty fresh than there is only one thing left in my mind. Do you run 91 octane in it full time or do your run a lower octane? My car did it with anything less than 91
Jeff1904
Jun 5, 2016 05:00 PM
PopoFormula
Oct 12, 2015 04:19 PM
colts0455
Oct 4, 2015 09:47 PM
SEOJustin
Sep 24, 2015 04:39 PM
