Cuts out at high rpms..
Old Jul 13, 2005 | 03:02 PM
96ta(nick)'s Avatar
My car acts like it is hitting the rev limiter at 6300 and cuts out yet my rev limiter is set at 6800 and on the graph it is still pulling hard when it just all of a sudden cuts out and drops. anybody have any ideas of why this is? It pulls just fine up untill that point and put down 396/375 at 6300. Mods are in the sig.
Old Jul 13, 2005 | 03:52 PM
jsetzer's Avatar
Re: Cuts out at high rpms..
OMG!!! OPTI!!! L33T HAX0R!
Why on very similar setups did Tibby put down the same HP, but rape you by 40lbs of tq? Thats something else I have been wondering. Or is it a spike on his tq converter. (Never seen his actual graph)
Nick's car pulls until you hit the rev limiter. (Bouces off of it) but datamaster only shows 6300ish, while the pcm is programmed to 6800 (checked myself). Your graph has a pull to 6500 then one to almost 7000 (again there is an error in the reading somewhere....) but on the one that pulls past 6500 the line goes to crap.
Have you outgrown your stock pump? Perhaps the ignition system just can't keep up there? Time for a good coil?
We need to do your fuel filter and check the plugs.
You want me to post your dyno graph?
Old Jul 13, 2005 | 03:58 PM
SoloExceptional's Avatar
My vote is for valve float, too small injectors or lack of fuel supply
Old Jul 13, 2005 | 04:02 PM
jsetzer's Avatar
He has 30s or 32lbs I forget. So injectors are good at this point. He has beehives so I doubt its valve float.... Could be pump though
Nick's Dyno
Old Jul 13, 2005 | 04:36 PM
96ta(nick)'s Avatar
Pump is stock with 120k on it so i would not doubt it.
Old Jul 13, 2005 | 04:43 PM
Maybe someone put a 3 instead of an 8 for the 6800 rpm limiter? lol As far as I know, When it drops off like that it's either lack of fuel or valve float but since we've eliminated one of the two, I'm gonna stand with the fuel pump issue, or perhaps you just need more, like the Walbro 255 everyone typically adds when they get up to that HP range
Old Jul 13, 2005 | 04:45 PM
jsetzer's Avatar
Just talked to him. Looks like thats the next mod. I may do one also.
Old Jul 13, 2005 | 05:08 PM
Whitewolf's Avatar
mine did the same thing.....
my problem was the ignition module.
Brad
Old Jul 13, 2005 | 10:31 PM
96ta(nick)'s Avatar
Brad
Hmm well the opti/coil/wires/plugs are new so it is either the pump or like you said the ignition module.. If the pump does not fix it i will try the module. I figure it could use a new pump anyway.
Old Jul 14, 2005 | 10:07 AM
1993Fast_Z's Avatar
it could very well be the pump, my car did the same thing..i lost a damn race cause of it...Fuel pump fixed it...it only had 130 K on it
Old Jul 14, 2005 | 10:09 AM
1993Fast_Z's Avatar
i doubt it is the Ignition Module...if it was..your car would get to the point where it wouldnt start after it got hot...im pretty sure..
Old Jul 14, 2005 | 10:26 AM
madwolf's Avatar
You're running lean from 3500 up. Get the fuel pressure measured first and if it's ok, then send the computer back for reprogramming. The cutting out up top is not your rev limiter and it's not you running out of fuel (although it is lean) it could be some MAJOR knock retard (which I doubt) or valve float.
Old Jul 14, 2005 | 01:23 PM
93transam1234's Avatar
Hey man, if you get it fixed please send me an email @ asadler@zalco.com
I am having the same problem with a simular setup to yours
Old Jul 14, 2005 | 02:10 PM
jsetzer's Avatar
I have his datamaster log at home. Starts out with 3-4 degrees retard down low. 2degrees by 3k. Then at 4k he hits 0.1 and stays there until 6k. Past 6k he has 0 knock retard.
Old Jul 14, 2005 | 03:12 PM
96ta(nick)'s Avatar
Well i doubt it is valve float due to the springs being dual coil(forget which ones)
with only 10k on them. My 306 was pulling to 6600 and still climbing when he let off.
And like jeff said, not really any knock retard.
I will check the fuel and my springs to see if anything is broken i guess.
