cuts out at 105
Old Nov 15, 2005 | 09:38 PM
19camaro71's Avatar
cuts out at 105
so i took the car out this weekend and in 4th gear... at roughly 3 grand a "rev limiter" like action happened and it wouldn't go faster. So my question is (and i am not sure where to post this, i am sorry for that) But what is the thing with this.. everything i have read points to the governor being set at 150. Is this different for 1993? Any input would work, thanks!
Old Nov 15, 2005 | 09:55 PM
rngilliland's Avatar
Re: cuts out at 105
If your car wasn't ordered with the Z rated tires it probably has the speed limiter set at about 105. IF your speedo only goes to 110 or so you have the limiter.
Old Nov 15, 2005 | 10:06 PM
Kingofthehill's Avatar
Re: cuts out at 105
my 94 trans am hasa a 110 speedo and also has a limiter at around 105-107mph...
sucks
JOe
Old Nov 15, 2005 | 10:16 PM
cas0484's Avatar
Re: cuts out at 105
Just get the limiter programmed out with a tune. Easy fix.
Old Nov 15, 2005 | 11:23 PM
1racerdude's Avatar
Re: cuts out at 105
Don't run but 104
Old Nov 17, 2005 | 07:28 PM
19camaro71's Avatar
Re: cuts out at 105
its got a 150 speedo... and as far as z-rated tires being ordered on it.. i have no clue
But I guess it is nice to know that it can be tuned out.. it will have to be with a chip for my car though.
Thanks much!
Old Nov 17, 2005 | 07:39 PM
flatlander757's Avatar
Re: cuts out at 105
Check your glovebox/doorjamb for the RPO codes and use this to see if it came with Z rated tires:
http://www.ls1tech.com/forums/showpo...6&postcount=18
Old Nov 17, 2005 | 08:46 PM
19camaro71's Avatar
Re: cuts out at 105
it came stock with 235/50R16 so i really don't think they are z-rated (hence the z not being present. Since it is a 1993 formula, it got a slightly narrower tire than the trans am (235 opposed to 245) same wheels though. So I am going to go with the conclusion that my governor is set at roughly 105, even though i have a gauge that will read way beyond that. Next spring I have a list of crap to do to it, as this year came to a close with our first snow today. This fall i have done a slew of BMR and bilstein suspension work.
Next year i'll get a chip for it.
Thanks again!!
Jeff1904
Jun 5, 2016 05:00 PM
94Maroz28
Oct 27, 2015 04:38 PM
PopoFormula
Oct 12, 2015 04:19 PM
colts0455
Oct 4, 2015 09:47 PM
