Cutout
yeah well it would be nice to have kickass sounding loud exhuast... then when im coming home late at night or driving to someones house late at night i wanna be able to close the cutout.... but not have it sounding like an exhaust leak
I just put a QTP elec cutout right before it goes into the stock muffler. I bought a header collector set, 3". The muffler shop charged me $30 to shape the collector, cut the hole in the stock pipe and weld it in. It is slightly pointed down and straight out the rear of the car. I figured it would sound better there without the resonoce you get right before the axle installed type. I then put the other collector on as a small tail pipe. I painted it with some black heat paint to hide it from rear view some. The pipe going into the muffler is 2-3/4" stock and 3" on most catback systems. It will leak a small amount when you close it while the car is running, but if I close it with the engine off then start it it the leak is very slight. Sounds good with the stock muffler when I want quiet and can give it just a little noise or a lot when I want. Can't wait to open it up half way through running a unsuspecting challenger. Sounds killer at WOT and high RPM.
Later>>>>>>>>>>
Later>>>>>>>>>>
tdigger9899
Sep 7, 2015 10:56 AM
May 21, 2015 01:04 PM
