csi waterpump overheating!!!
Old Jan 15, 2005 | 12:31 PM
z28importkilla's Avatar
i drove my car today and it was running fine the whole day. I stopped and pulled a little burner and about 5 min. after that. it was overheating badly. I have a CSI electric water pump. I tried refilling the antifreeze, starting the car until the thermostat opened, and then tried bleeding the system, but i get nothing out of the bleeder valve. It is a brand new radiator and thermostat. any ideas?
Old Jan 15, 2005 | 12:38 PM
Birdman7389's Avatar
Re: csi waterpump overheating!!!
How old is the pump? Check your connections, fuse and relay for it. Turn the key to "On" with the engine off and listen/feel for it. Does the pump run?
Old Jan 15, 2005 | 12:50 PM
fuse looks good b ut not sure how to check to see if the relay is bad. When the ignition is turned to "on" you can hear the pump making like a buzzing sound so i assume it is pumping but i still cannot get it to bleed.
Old Jan 15, 2005 | 01:14 PM
Flyin_Z28's Avatar
Do anyone know if CSI Electric Pumps have set screws?
I heard some electric water pumps do. If there is a set screw, it may have come loose and free-spinning, thus no pressure in the system to bleed. Just a thought.
Old Jan 15, 2005 | 02:04 PM
Hmm, are you trying both Bleeders? I know one wont work unless the Thermo is open?
Old Jan 15, 2005 | 04:44 PM
ShawnMacAnanny's Avatar
Did you check your oil, and are you seeing any smoke? Could be a blown head gasket.
Old Jan 15, 2005 | 05:01 PM
i tried both bleeder valves and i checked the oil and it is fine
Old Jan 15, 2005 | 05:12 PM
NOMAD's Avatar
No set screw. You probably just need to finish bleeding it out. It takes mine a good while when I swap heads and such. Bleed it for a bit, drive it, and see if it overheats, if not, leave it alone, if so, bleed more
-Shannon
Old Jan 15, 2005 | 08:12 PM
Ken95Z28's Avatar
With the key (engine not running) on you should see some coolant flowing through the radiator with the cap off. This will tell you if the pump is working or not. You must do both bleeders and make sure you get all the air out. When you did the bleeders did fluid come out?
You did wire the CSI correctly? If the wiring was done backwards than this could be the cause of it.
Old Jan 15, 2005 | 08:41 PM
Seal's Avatar
one of the reasons i'll never get an electric water pump
what if it fails?
Old Jan 15, 2005 | 10:18 PM
turbo_Z's Avatar
I never had to bleed the system on mine like you would with the stock wp. I just turn the key ON so the pump will run and let the coolant circulate around that way. Once the radiator is full you shouldnt have to bleed anything really.. or I didnt anyway and have done it several times now.
damnyankee36
Sep 9, 2015 07:06 PM
Pwilson59
Sep 3, 2015 08:47 PM
reww86
Aug 29, 2015 06:04 PM
MikeWhitener
Aug 2, 2015 06:17 PM
