CSI install..do u i need a diod?
Old Feb 19, 2004 | 08:34 AM
xxsaint69x's Avatar
http://ken.lowrance.com/Projects/CSI.../Schematic.jpg
What do i need a diod in there for?
Also what kind should i get?
thanks
Marcin
Old Feb 19, 2004 | 08:39 AM
teke184's Avatar
isn't it just for an "idiot light" to confirm the pump is working?
in case it decides to die on you you can tell by poping the hood and checking the little light?
Old Feb 19, 2004 | 11:53 AM
xxsaint69x's Avatar
i dont know
Old Feb 19, 2004 | 11:56 AM
T/A lt1's Avatar
Yep that is what it's for to keep an eye on wether or not your pump is working. I didn't put one on mine b/c I keep close watch on the gauges anyways. But my pump has gone out on me already and it sucks. Later Clint
Old Feb 19, 2004 | 11:58 AM
Brandon 95 Z28's Avatar
I didnt use a diod or swithc on my CSI, and it has been great for 2 years. I just have mine set to come on with the key in the ACY position, and with the car running. The switch is optional as is the diod, good luck!
Brandon
Old Feb 19, 2004 | 12:07 PM
xxsaint69x's Avatar
yeah, screw the switch and the light, i keep a good eye on my guages all the time anyways.
Old Feb 19, 2004 | 12:47 PM
x7x7's Avatar
the diode is for the switch, so that if you want to run the pump with the car off you can without supplying power to the ignition curcuit.
Old Feb 19, 2004 | 01:22 PM
ibanez6rg's Avatar
Switch might not be a bad idea, if you need to fill your block up, if ever drained.
HarleyZ28
Oct 5, 2015 06:23 AM
4586
Aug 18, 2015 07:08 AM
Brian Demeter
Oct 4, 2002 06:35 AM
CJ Black LS1 Z28 M6
Middle Atlantic
Jun 15, 2002 10:12 PM
