CSI install?
Old Jun 10, 2003 | 04:02 PM
95_RipperZ's Avatar
CSI install?
I just finished grinding out the grooves for the ears to go into, my question is, can is use the bolts the suck the water pump down flush wiht the waterpump housing or do I need to grind the grooves out enough so it just sits flush without the bolts in?
Old Jun 10, 2003 | 04:14 PM
kirschman's Avatar
I would recommend grinding it till it fit flush. U can go "pretty" far with the grinding if u need to with out any probs. Using bolts to pull two engine parts together is usually not good, that means it doesnt want to fit. I grinded mine till it fit flush.
Nov 18, 2023 07:21 PM
HarleyZ28
Oct 5, 2015 06:23 AM
1996LT1Z28
Apr 14, 2015 07:15 PM
lbrowne
Nov 13, 2011 04:25 PM
Ken95Z28
Aug 21, 2002 04:32 PM
