Cruise control went...
Old Feb 7, 2004 | 08:55 AM
Myxtreme1's Avatar
Well I knew it was going to happen but why did it happen? One day it worked fine, then I was on the way to work the next and there was nothing. So what goes out for this to happen and how do I fix it? Thanks!
Old Feb 8, 2004 | 12:55 AM
Myxtreme1's Avatar
anybody?
Old Feb 8, 2004 | 04:22 AM
QCKZ28's Avatar
i took mine off the car for weight reduction. it worked perfect.
do you want to buy mine?
let me know
jessedeskins@hotmail.com
jesse
Old Feb 8, 2004 | 10:58 AM
Bud M's Avatar
Mine quit when I burned out a bulb in the wing brake light. Replacing the bulb fixed it.
Old Feb 8, 2004 | 11:17 AM
Myxtreme1's Avatar
let me know
jesse
How much weight did you save by doing so?
Bud M:
Thats crazy...I know one of mine is blown so I'll try that. Thanks guys!
Old Feb 8, 2004 | 11:31 AM
texasTA's Avatar
let me know
jesse
how much weight does that save??? mine does not work either?
Old Feb 8, 2004 | 11:52 AM
Pandamonkey's Avatar
GM's multi stick has always been known to have a few problems from time to time..........the cruise went on my Blazer and my fathers truck - it was discovered that the multi turn signal/wipers/cruise control tree was the problem in both cases.
There's a lot going on in that little stick.......
Old Feb 8, 2004 | 12:04 PM
Brundle's Avatar
Same thing happened on by winter beater car (chevy lumina).
replaced the multi-function arm, and it worked fine. good thing too cause the arm was 50 bucks, cruise unit was over 200. i would think it would be the arm before the cruise unit n e ways. i mean, look at the use the arm gets as compared to the cruise unit, makes sense that the one with more use on it would crap out first
Old Feb 8, 2004 | 12:19 PM
carlos64030's Avatar
The switch that disengages the cruise control when you step on the brake or clutch pedal could've gone bad.
Old Feb 8, 2004 | 12:26 PM
Myxtreme1's Avatar
I'm pretty sure I need to replace the stick.
Old Feb 8, 2004 | 12:34 PM
NewbieWar's Avatar
mine stopped working... i replaced both lights and if im patent with it, it'll kick in only to accelerate then i make it stop accelerating then it stops working
Old Feb 8, 2004 | 02:58 PM
QCKZ28's Avatar
somewhere around 3-4lbs
jesse
Old Feb 8, 2004 | 03:18 PM
indieaz's Avatar
Mine went the same time my bulb int eh wing went out as well...i haven'treplaced tbe bulb yet to make sure that was it. But semeed more than coincidental that they both went at the EXACT same time =) So i would check your upper brake light bulb first.
Old Feb 8, 2004 | 08:14 PM
jr811's Avatar
1994 Z28- I replaced my coil wire and cruise worked fine.
I took my Z28 to dealer to get cruise fixed. $750.00 to fine out
coil wire need to be replaced
Old Feb 8, 2004 | 11:05 PM
blackbirdta's Avatar
my cruise went out and i took it to the gas station we're friendly with and they said everything checked out so i'd have to take it to a dealer for further investigation....but i figured that would be expensive so i just said forget it...
how would something like a light or coil cause the cruise to go out? i'd like to fix my cruise control w/o getting jacked by a dealer
i dont think i have any bulbs out...
