Cruise Control Cable Routing
Old Sep 3, 2003 | 06:52 PM
Chuck2's Avatar
IVe got a 96 Lt1 without TRaction control. I know that since I have long tubes I need to run it inside that heat shield on the drivers' side. I need to know where it goes from there. I know it goes to the TB but it has to fasten to something else on the firewall or close ot it b4 that. Thanks
Old Sep 11, 2011 | 09:20 PM
RallyBoy1's Avatar
Re: Cruise Control Cable Routing
Does anyone have a pic of how the cable is run? Where does it clip to on the frame rail? Sorry for bringing up an old thread.
Old Sep 12, 2011 | 01:13 AM
97WS6SCharged's Avatar
It should run to the cruise control module on the driver side rail.
Old Sep 12, 2011 | 08:26 PM
ACE1252's Avatar
I'll try to get a couple of pictures for you tonight.
Old Sep 12, 2011 | 08:58 PM
ACE1252's Avatar
Module bolts to the driver's frame rail, comes up right at the k-member then routes like so....also, I think it has a retainer that gets pushed into the bottom of the plastic brake line clip.
It then goes around the left side(referenced from drivers seat) of the brake booster....there is a clip on the cable that you slide onto the flange of the booster....
From there it is up and over the booster to the throttle body.
thenewkid
Apr 12, 2015 07:42 PM
njspder
Middle Atlantic
Mar 5, 2015 05:39 AM
cmdeshon
Dec 27, 2014 10:06 AM
Jul 4, 2005 05:00 PM
